2024年05月22日  首页公告版规
查看: 5738|回复: 17
[网友交流区] 2004 Volkswagen Jetta (也就是宝来)
发表于 2009-1-18 15:50:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
改装清单细翻译起来太过复杂了,大家就自己看吧
Engine: 1 b9 K G  N) W  P. b& k
SPA 60-48 GT30R turbo DTR Ported Polished head, DTR Tubular style welded 4-1 turbo manifold w/ DEI wrap, DTR 4-inch custom stainless steel polished intake pipe, DTR Polished aluminum intake manifold, DTR Polished stainless steel intercooler piping, DTR 3-inch stainless steel V-band side exit exhaust w/ twin tips, DTR Polished stainless steel breather catch power steering tank, TiAL 44-mm wastegate, Bosch 800cc injectors, ATP polished fuel rail, Aeromotive 700 inline fuel pump, S-MAX adjustable FPR, S-MAX SW300 BOV, S-MAX intercooler, S-MAX vacuum manifold, DEI Cry Intercooler sprayer & fuel cooler, VF engineering engine mounts, Samco silicone hoses, Worth Zebra heavy duty clamps, Neuspeed power pulleys, Polished OBD1 VR6 Throttle body, 034 Stage 2c with wide band EGO sensor, 6 SPEED w/ Quaife LSD South-bend stage 3 clutch
Exterior: $ L0 \% H/ k6 z3 h7 M
DTR Metal Widebody, DTR stretched metal sideskirts, Zender Racer R front and rear bumpers (modified), VIS carbon fibre hood and trunk, APR carbon fibre: GT200 wing, front splitter, GT3 mirrors, FK angel-eye projectors, Blue Lagoon Metallic by Custom Collision, Graphics by Balance Point Graphics
Wheels/Tires/Brakes: ' e8 h h2 n$ p
Forgeline SP3-P 19x10 front, 19x12-inch rear with Falken FK452 265/30R19 front, 315/25R19 rear tires, ECS tuning stage 5 15.1-incj 2 piece rotor w/ 6-piston Porsche calipers, ECS tuning 12.1-inch rear brakes w/ 4-piston calipers
Suspension: : P. A9 V$ c, O' m O! q" k
Easy-street sport suspension by Air Lift, Neuspeed front and rear sway bars Neuspeed upper and lower front tie bars Custom poly rear bump stops
Interior:
DTR 4-point chromoly cage, Recaro SPG seats MOMO 4-point harness belts, MOMO air metal steering wheel, shifter and e-brake handle, AEM Electronic gauges: Tru boost controller, Wideband, Voltmeter, fuel/oil pressure, Autometer programmable shift light/tachometer, Custom micro suede interior accents, ABD door sills and pedals, Pro Werks polished aluminum Co2 Bottle brackets : s% J3 C1 A- d2 w# e$ K
Clarion DVD MAX 675VD head unit, Rockford Fosgate Power 1000 5-channel amp, Rockford Fosgate T162s 6.5 component sets front and rear, Rockford Fosgate wiring, Rockford Fosgate power T1-15 subwoofer, 3Sixty.2 sound processor Kinetic HC1800, HC600 batteries DEI Boot Mat sound-deadening " g: u% I6 I2 ^+ w% s& o
Sponsors: ' k' x' t) O# q2 U  l1 j, l* ~. T; |2 O
FORGELINE WHEELS, FALKEN TIRES, S-MAX, AEM, DTR PERFORMANCE, VIS RACING, APR, SAMCO, 034 MOTORSPORTS, ECS TUNING, DEI, MOMO, RECARO, BALANCE POINT GRAPHICS, KINETIK, ROCKFORD FOSGATE
【沙发】
 楼主| 发表于 2009-1-18 15:51:35 | 只看该作者
【板凳】
 楼主| 发表于 2009-1-18 15:51:57 | 只看该作者
【凉席】
 楼主| 发表于 2009-1-18 15:52:18 | 只看该作者
【地板】
 楼主| 发表于 2009-1-18 15:52:40 | 只看该作者
6
发表于 2009-1-19 01:14:19 | 只看该作者
很酷的车改的1
7
 楼主| 发表于 2009-1-19 08:54:27 | 只看该作者
原帖由 一六三 于 2009-1-19 01:14 发表 很酷的车改的1
呵呵 改这样的 估计也要花不少钱
8
发表于 2009-1-19 09:54:54 | 只看该作者
音响也改了
9
发表于 2009-1-19 19:55:20 | 只看该作者
19寸的轮毂,这个车身避震不好,那就完了。。。
10
发表于 2009-1-20 09:01:07 | 只看该作者
强的了 NIU
11
发表于 2009-2-10 09:11:53 | 只看该作者
轮毂 喜欢
12
发表于 2009-3-29 10:08:24 | 只看该作者
赞个 改的太棒了
13
发表于 2010-5-9 12:06:40 | 只看该作者
这才像辆改装车吗!
14
发表于 2010-5-10 16:42:52 | 只看该作者
蓝色的车身,黑色的大盖。给人一种梦幻的感觉。
15
发表于 2010-6-11 09:17:27 | 只看该作者
不敢恭维…
16
发表于 2010-6-27 18:48:53 | 只看该作者
那个大瓶子里装的是什么呢
17
发表于 2010-6-27 18:57:04 | 只看该作者
好像是mk-2
18
发表于 2010-6-28 17:32:56 | 只看该作者
JETTA不是捷达吗? 我不知道 我瞎说的啊
GMT+8, 2024-5-22 10:32 , Processed in 0.116476 second(s), 24 queries .
